Shapefile fieldnames - ALWAYS UPPERCASE?
  • Feb 19, 2013 11:09 PM UTC
  • 192 views
simonl
Forum|alt.badge.img+9
Hi just wondering if you can write shapefiles with mixed case fieldnames? I understand the issue probably lies with the underlying DBF structure, but the shapefile reader acknowledges the case just not the shapefile writer. Am I missing something or is there a way to stop all fieldnames being UPPERCASE?
  • Feb 20, 2013 4:17 AM UTC
When adding SHP writer on your workspace, open Parameters dialog box and uncheck "Use Upper Case" check box.
sigtill
Forum|alt.badge.img+25
  • Feb 20, 2013 8:53 AM UTC
You can also made this the "default" behaviour for SHP:
  • Feb 22, 2013 1:38 PM UTC
To add to the excellent answers below: Just be aware that some software packages might have problems with mixed case Shape files.
David
