Setting Esri Shapefile name in Writer
  • Jan 7, 2016 2:42 PM UTC
  • 92 views
ceciliac
I am using Workspace runner to clip several shape files. I have created a Published parameter (Filename (Output) - ESRI_SHAPE. The ESRI shape writer that i am using is using a destination folder and I would like to change to Destination ESRI shape file.
jdh
Forum|alt.badge.img+41
  • Jan 7, 2016 2:51 PM UTC
The way the esri shapewrite works is that the DestDataset_ESRISHAPE is a folder, and the name of the shapefile comes from the feature type. Either dynamically from the fme_feature_type or set explicitly on your feature type.
gio
Forum|alt.badge.img+15
  • Jan 7, 2016 3:01 PM UTC
There area couple of way sto do that.
For instance you can use a scipted one like this
DestDataset_SHAPE =
$FME_MacroValues(Dir_out)\\\\$FME_MacroValues(File_Out)
Dir_out and File_Out are your published parameters.
Forum|alt.badge.img+5
  • Jan 7, 2016 3:10 PM UTC
Shapefiles fanout on the writer will create a new shapefile per fanout unique name, like a group by. If you need to create a new folder for each shapefile output you need to use fanout dataset in the advanced section.
If I understand your question correctly then change the feature type name in the writers options to your published parameter. That should name each shapefile accordingly.
erik_jan
Forum|alt.badge.img+26
  • Jan 7, 2016 3:26 PM UTC
The filename can be defined in the Feature Types Properties using a published parameter or an attribute. This image shows where to look:
