Setting Appearance on a Mesh
  • Mar 29, 2019 12:12 PM UTC
  • 98 views
Hello Everyone,
I have a mesh in dwg format. The FME Geomtry is composite surface, I can coerce it to Mesh.
I have a georeferenced tiff image which I want to set as appearance using the AppearanceSetter.
These are the parameters I use (using both front and back side).
The problem is I get the appearance on the wrong side of where I want it to be (fig1 demonstrates results, fig2 demonstrates the side I want it to be). Tried the orientor, same result.
Any ideas?
Thank you for your time.
Kind regards,
George Floros
daveatsafe
Forum|alt.badge.img+24
  • Mar 29, 2019 5:06 PM UTC
Hi @georgefloros,
Please try changing Use Existing Texture Coordinates in the AppearanceSetter to No.
