Set Z values
  • Jul 23, 2018 8:39 PM UTC
  • 949 views
jdh
Forum|alt.badge.img+41
Is there a way to set different Z values for each vertex of a line/polygon from a list, like the MeasureSetter in Whole Line/Area mode?
The 3DForcer sets all the vertices to a single elevation, and the VertexCreator replace point at vertex i only does one vertex at a time.
Best answer by takashi
Hi @jdh, you can call the @ZValue function (one of FME Feature Functions) with the FMEFunctionCaller. Assuming that the "_list{}" contains z values for the line/polygon:
@ZValue(_list{})
Notes:
  • Input geometry should be 2D.
  • The number of list elements should be exactly equal to the number of geometry coordinates.
  • If the input geometry type is polygon, the last element of the list should be equal to the first element (i.e. the resulting vertices should be closed in 3D).
geosander
Forum|alt.badge.img+7
  • Jul 23, 2018 8:54 PM UTC
Hi @jdh,
Personally, I'd do it in a PythonCaller/Creator, but using transformers, you could try the VertexExtractor from FME Hub perhaps? Then join the Z values in your list (based on the vertex id and some line/polygon break attribute), set the height using the 3DForcer and reassemble the lines/polygons using a PointConnector (but use the Sorter first)?
jdh
  • Jul 23, 2018 9:03 PM UTC
Hi @jdh,
I've done it in Python before, but most of my colleagues are not comfortable with Python.
  • Jul 23, 2018 10:50 PM UTC
@ZValue(_list{})
Notes:
