SDE and Oracle data
  • Feb 12, 2014 6:52 PM UTC
  • 69 views
francis_m
Forum|alt.badge.img+9
I have a Oracle database that store ArcSDE data.
I read mapinfo data with FME (MAPINFO reader)
And I write the data with FME (SDE30 writer)
I use : FME(R) 2012 SP4 (20120926 - Build 12266 - WIN32)
It's the same problem on server or desktop.
My problem is about an attribut.  It's a unique ID (ID_ORIGINE) that goes like this :
Mapinfo value : 7271203048662889
FME (logger) value :  Attribute(string)  : `ID_ORIGINE' has value `7271203048662889'
It's the same.  But when I open my ArcSDE table with ArcMap or visualize the data from within Oracle with SQL Developper I have this : 7271203048662890
The end of the number is rounded (2890 instead of 2889).  But I didn't ask for this.
My data structure :
Oracle : Number
SDE : Double (precision 38 and scale 10)
so it should go well cause If I insert it manually it's OK.
But when FME write it down : the value is rounded.
Is it FME that round the value while writing it down or Oracle or SDE that do the trick?
Any idea?
I know I can change the data structure but we are in PROD so change to database is not an option for now...
fmelizard
Forum|alt.badge.img+22
  • Feb 12, 2014 7:13 PM UTC
Hi, when writing to an FFS is the value rounded? if that is the case than its probably FME otherwise the target database, that would be my initial test.
francis_m
  • Feb 12, 2014 7:23 PM UTC
thanks for the reply.
The ffs contains the value as it should be : 7271203048662889
Is it SDE or Oracle?
