Running into issues using TempPathnameCreator > HTTPCaller > FeatureReader
  • February 5, 2025
  • 23 views
hodsen96
Forum|alt.badge.img+4
Hey all,
In my previous post It was suggested to use TempPathnameCreator to download these files and once processed, the location and file will be deleted, saving disk space. However, I am unable to view any data in the FeatureReader. In this instance, my FeatureReader has 905 records under the <Generic> Port, but when I view it via Feature Caching, it says “No Schema” for the attribute name and all the values are empty. However, If i click the Columns and hit “select all” it seems that I can actually see the tables, but I can’t seem to access the data with an attribute remover or the likes.
Do I need to expose some attribute within the Generic Port <Attributes to Expose>?
Any help will be appreciated! Thank you!
Best answer by hodsen96
Seems I’ve figured it out...Grab a AttributeExposer and set it to Import > Feature Cache. This will let you select all the columns you want which are related to the CSV….Sorry for wasting y’alls time...
hodsen96
  • February 5, 2025
