Rounding coordinates when reprojecting from and to Oracle Spatial Object tables
  • Jan 28, 2014 10:09 AM UTC
  • 72 views
esko
Hello,
I'm doing a straigth-forward conversion of Oracle SDO_GEOMETRY from srid 294914 (old national coord.base) to srid 3067 (new national coord.base) using just Oracle reader and writer.  Is there any way to reduce the number decimals in the output, at the moment converting from
3385034.91; 6678837.36  (east; north)
produces
384911.612948413; 6676033.80278682
Best solution would be to have some parameter in the writer to round or cut  to a desired number of decimals .  I assume that using some transformer (like CoordinateRounder) between reader and writer would substantially increase the execution time ?
Esko
Best answer by fmelizard
The transformer will not necessarly increase the execution time, from my experience usually the reading & writting takes longer than mid-transformation.
An optional manner would be to use a database function to reduce the decimal accuracy.
Itay
fmelizard
Forum|alt.badge.img+22
  • Jan 28, 2014 10:20 AM UTC
Itay
