Reverse Engineer kml (xml) fly over and orbit
  • May 16, 2017
  • 0 replies
  • 28 views
I'm am already way over my head on this on this one. I'm trying to create several hundred kml files each one showing a specific area and slowly orbiting abound that area to show a 360 view. I have created a sample kml in google earth. Please see the attached kml. I have also attached a copy saved as .txt so you can see the xml code the kml created. Is it possible to create similar kml files in FME. I have played around with the KMLTourBuilder and the KMLViewSetter but was unable to replicate. I'm not a programmer and can't wirte xml on my own but would like to somewhat automate the process so I don't have to create each one in the Google Earth UX. Any suggestions would be very appreciated. THANK YOU THANK YOU
