Request for input s- Unable to update the date field record using arcpy updatecursor in FME
  • Mar 13, 2024 2:42 PM UTC
  • 5 replies
  • 159 views
spill002
Hello,
I am trying to update the date field records of a feature class using arcpy update cursor, but I am getting the following error (text in bold), please let me know If I am missing anything :
Field Name : e_result_datetime
Field Values : 20230803081554
Field datatype : Date
Also, want to mention that I am able to update the string, double data type fields using updatecursor in FME with no issues - it’s only with date data type I am facing the problem.
Python Exception <RuntimeError>: The value type is incompatible with the field type. [e_result_datetime]
Traceback (most recent call last):
  File "<string>", line 46, in input
RuntimeError: The value type is incompatible with the field type. [e_result_datetime]
Error encountered while calling method `input'
PythonCaller (PythonFactory): PythonFactory failed to process feature
Best answer by nielsgerrits
Thanks for looking at it and sharing your thoughts on it, but still I am getting an error.
Please find the below snapshot of the same :
I think it needs to be
%Y-%m-%d %H:%M:%S
and not
%Y-%m-%dT%H:%M:%S
nielsgerrits
Forum|alt.badge.img+67
You will need to reformat the date from fme datetime to something ESRI understands.
You can use a DateTimeConverter to do this. It needs to be formatted as %Y-%m-%d %H:%M:%S
spill002
  • Mar 13, 2024 2:58 PM UTC
nielsgerrits
  • Mar 13, 2024 3:07 PM UTC
%Y-%m-%d %H:%M:%S
and not
%Y-%m-%dT%H:%M:%S
spill002
  • Mar 13, 2024 3:17 PM UTC
Thanks a lot, appreciate for looking at it and sharing your inputs on it.
Our issue got resolved.
nielsgerrits
Happy to help :)
