Replacing point-features with an Autodesk 3DS-file
  • Dec 5, 2012 4:41 PM UTC
  • 55 views
Hello again,
anyone know a quick solution for displaying an Autodesk 3DS-model of a tree for each point in an ESRI-point-shape?
I will eventually merge it with a DEM an Orthophoto and 3D-buildings and write a 3d-PDF.
Thanks for your considerations
Patrick
davideagle
Forum|alt.badge.img+21
  • Dec 6, 2012 1:03 PM UTC
I've read that you can have 3D Autodesk 'Blocks' so I think you might want to look at creating a block for your tree and then use FME to set each point to use that block from your template file.
There's a bit more info here:
http://fmepedia.safe.com/articles/How_To/Creating-AutoCAD-Blocks-with-FME
  • Mar 5, 2013 10:39 AM UTC
Hello,
I have the same problem: I would like to assign to my ESRI-point-shape a 3DS symbol according to an attribute value, before representing in a pdf3D. Which transformer would be able to do the job?
Thank you for your help.
Mayeul
