Remove feature dataset when writing to ESRI file-geodatabase?
  • October 10, 2014
  • 122 views
jess
Hello!
   I'm curious if there is a way to strip away the feature dataset information when using an ESRI file-geodatabase writer (GEODATABASE_FILE, dynamic mode)? My workbench reads a series of layers from an SDE database, performs some geoprocessing and then writes all the data to a new file geodatabase. I'd like to remove the feature dataset names which come from the SDE and output the layers in the root of the fGDB. Any suggestions?
Thanks in advance,
~jess~
Best answer by david_r
one way could be to insert a BulkAttributeRemover with "geodb_feature_dataset" as the expression.
David
jess
  • October 10, 2014
A better way to ask the question.... how do I specifiy 'root' for this writer property?
  • October 13, 2014
David
jess
  • October 14, 2014
Great. Thanks David!
