receive "FFS writer: Failed to write to file" while reading large dataset
  • January 24, 2020
  • 425 views
I want to perform spatial operation (point in polygon) using Spatial Relator. Point dataset has 30 millions of records. I have used Oracle spatial reader to read the dataset. But After reading nearly 15 millions of records , fme job was failed with error. "FFS writer: Failed to write to file..Please ensure that you have sufficient privileges to write this file, and that sufficient disk space is available" ..
Is there any way I can read all point records at a time without error?
Memory stats before start:
START - ProcessID: 29545, peak process memory usage: 16893 kB, current process memory usage: 16893 kB
System Status: 7.83 GB of disk space available in the FME temporary folder
System Status: 18.42 GB of virtual memory available
Operating System: Red Hat Enterprise Linux Server 7.7 (Maipo)
FME Platform: linux-x64
The memory allocator being used by FME is : `/lib64/libtcmalloc_minimal.so.4'
FME Configuration: Process limit is 15.67 GB of physical memory
FME Configuration: Start freeing memory when process usage exceeds 17.25 GB of virtual memory
FME Configuration: Stop freeing memory when process usage is below 12.94 GB of virtual memory
Forum|alt.badge.img+53
It shows you have 7.83 GB of disk space available for temporary files, that's not a whole lot. You can try two things:
  1. Free up disk space on the drive where your temp folder is
  2. Set the FME_TEMP environment variable to a different drive, with more free space.
Thanks for Answer. There are limitations to increase the FME_TEMP variable space. Also It is not possible for us to attached different drive to FME_TEMP variable.
So We decide to execute the workplace in batch of 10 million records..
