Reading Multiple text files
I have an attribute called text_lined_data that contains 6 data columns. How do i extract that information into 6 columns and line one as header?
danilo_fme
Forum|alt.badge.img+45
  • January 10, 2018
Hi @mortenag,
Could you share this sample data?
Danilo
danilo_fme
  • January 10, 2018
Are you reading a CSV file?
jdh
Forum|alt.badge.img+28
  • January 10, 2018
Instead of using a text reader, try using a CSV reader with the separator character set to ;.
If that's not possible, and the header is always consistent, you can skip the first feature, and use an attributeSplitter on the text_line_data, (;) and then manually rename the resultant list to the correct attribute names.
