Reading a tsv file
  • Sep 5, 2024 12:42 PM UTC
  • 160 views
p15rajan
Forum|alt.badge.img+7
Hello there,
How can I read a tsv file in FME? Do we need  to use csv format only:?
Thanks,
Siva
Best answer by mark2atsafe
Yes, you can use the CSV format and just change the delimiter in the parameters dialog.
There’s also a CAT (Column Aligned Text) format too, if the contents are aligned like that.
mark2atsafe
Forum|alt.badge.img+59
  • Sep 5, 2024 1:25 PM UTC
p15rajan
  • Sep 5, 2024 1:27 PM UTC
Thanks very much for your prompt reply
