Reading a CSV file with multiple coordinates in one attribute
  • Apr 8, 2019 5:00 PM UTC
  • 95 views
I'm using the Data Interoperability extension and I'm attempting to read in a csv file that has a column with a string of coordinates in it. I've tried loading it into the Spatial ETL Tool CSV reader, using the coordinate concatenator and then the area builder. I get a rejected feature warning when I try running the tool. Can anyone offer some pointers for this?
Best answer by erik_jan
Use a AttributeCreator to concatenate the coordinate string into this format:
POLYGON ((0 0,10 0,10 10,0 10,0 0))
Then use the GeometryReplacer (OGC Well Known Text) to read the attribute as geometry.
Hope this helps.
dustin
Forum|alt.badge.img+36
  • Apr 8, 2019 5:14 PM UTC
Use an AttributeSplitter based on ";" to breakout each coordinate.
erik_jan
Forum|alt.badge.img+26
  • Apr 8, 2019 5:21 PM UTC
Hope this helps.
  • Apr 10, 2019 2:03 PM UTC
Hope this helps.
Thanks for the response.
