Reader Issues with ArcGIS
  • Aug 12, 2015 7:21 PM UTC
  • 73 views
We are still having issues with having to re-add all readers that are hitting SDE or SQL every time we close an FME job then re-open the job. It will read nothing from the Reader. Then as I said, we have to re-add it, delete the existing one, and everything is fine. This is not acceptable and we've been doing it for a few months. Has anyone else had this issue?
  • Aug 13, 2015 6:46 AM UTC
Hi
Which version of FME is this? In my experience this issue seems to have been completely fixed since FME 2015.1.0.3.
You might want to consider installing the absolutely latest version from the download section.
David
  • Aug 13, 2015 11:52 AM UTC
David I reinstalled and it looks like this might have fixed it. If that changes I'll repost that here. Thanks for your answer.
