Read Multiple GDBs saved on SharePoint
  • February 28, 2024
  • 52 views
galigis
Forum|alt.badge.img+20
Hi All,
Is there any way to read multiple GDBs saved on the company Sharepoint? Does the Sharepoint need to be publicly accessible? I get an error when try to use the URL link and load the GDB,
Also I would like to know a workaround to read individual GDBs, Any Ideas? The GDBs are saved in individual folders so need to iterate thought these, example of the folder structure below:
Example of the individual content folder below:
Best answer by nielsgerrits
How I do this:
  • SharePointOnlineConnector to list the directory.
  • SharePointOnlineConnector to download the gdb.
  • FeatureReader to read the gdb.
I usually use the TempPathnameCreator to write the downloads to a temp file which gets cleaned up automatically, but I’m not sure that works well with .gdb’s as a file geodatabase is essentially a folder with an extension…
Also see the article Getting Started with Microsoft SharePoint.
  • February 28, 2024
How I do this:
