Wonder if there is a direct way to use a reader or feature reader to read a zipped up fgdb stored on google drive. One options is to use google drive connector to download the fgdb to the local drive. Thanks!
Read file-gdb on google drive
Best answer by takashi
Hi @bo, You may not have privilege to write a file into the /home directory. Try downloading the file into a folder under the /Users/<username>.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
