Read AutoCAD files to be processed from a text file
  • Jul 19, 2020 2:59 AM UTC
  • 90 views
rudystricklan1
I have a text file that contains an AutoCAD pathname on each line, e.g.,
D:\\project4033\\dwg\\p1234.dwg
D:\\project515\\dwg\\p642.dwg
X:\\dwg\\a556.dwg
How can I set up a Reader to process each file (the output format will be Adobe GeospatialPDF)? I see answers like a "TextFileReader", but on my 2020.1 system there is no such transformer.
Best answer by becchr
hi @rudystricklan1, there is a Text File Reader which you should be able to use? It reads your text file and makes a separate feature of each line of text, so for your example:
you can use these features to feed a feature reader which reads your dwg's:
Set to 'single output ports' at the bottom and you could use a FileExistenceChecker between both readers to make sure every dwg-file (line in your txt-file) actually exists
Hope this helps
becchr
Forum|alt.badge.img+35
  • Jul 19, 2020 8:29 PM UTC
Hope this helps
rudystricklan1
Hope this helps
@becchr, this answers my question completely. My FME background is... a little light and it shows :-). Thank you very much for the detailed answer-- I marked it as accepted.
Best regards,
Rudy Stricklan
