Publish to FME Server: Workspace Name issue,
  • Feb 14, 2014 5:28 AM UTC
  • 59 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out why “Publish to FME Server” doesn’t take the name of my file as “Workspace Name” but instead it takes other name
My file name is: UrbanMasterPlan_CAD_To_GIS_03.fmw
The name read by the FME (Workspace Name) is: T1_Published
From where the “T1_Published” is read considering that the name of my file is “UrbanMasterPlan_CAD_To_GIS_03.fmw” as shown in the screenshot below
What might be the issue here?
Thank you
Best
Jamal
kathyross
Participant
Forum|alt.badge.img+9
  • Participant
  • Feb 21, 2014 5:15 AM UTC
It may be the case that the workspace had been previously saved as T1_Published.fmw and so defaults to this name. If this is the case, it is likely hardcoded within your *.fmw itself. To check this, simply open the *.fmw in a Text Editor such as Notepad and search for T1_Published.
Typically though, FME Server defaults to either:
- blank (if the workspace is not saved)
- the name of the workspace
- or the name the workspace has previously been published via.
jamal
  • Feb 26, 2014 8:14 PM UTC
Many thanks SpatialKathy.
I couldn’t find the T_Published on the code
what other issues should i conisder?
