Process fails due to reader error, despite 'ignore failed readers' being set
  • Aug 10, 2017 11:07 PM UTC
  • 17 replies
  • 283 views
chriswilson
Forum|alt.badge.img+29
I have a workspace that is aimed at accepting either a shapefile or a DWG to define an area of interest which in turn is used to find data. I've linked both readers to optional parameters, blank default sources, and set 'ignore failed readers' to yes, yet when only uploading a shapefile (i.e. not uploading a DWG) I still get a process failure on FME Server with this message about the DWG reader failing:
I can try later with feature readers, but to me this shouldn't fail - any ideas?
mygis
Forum|alt.badge.img+14
  • Aug 11, 2017 12:05 AM UTC
Hi Chris. Could you please share the log file?
thanks.
Lyes.
chriswilson
  • Aug 11, 2017 12:09 AM UTC
thanks.
Lyes.
Sure
job-764.zip
danilo_fme
Forum|alt.badge.img+58
  • Aug 11, 2017 2:41 AM UTC
Sure
job-764.zip
Hi @chrisw84, this log file is not the same your screen above.
Thanks,
Danilo
chriswilson
  • Aug 11, 2017 3:08 AM UTC
Uploaded the wrong log file in a hurry, here's a more useful one.
job-761.zip
pratap
Forum|alt.badge.img+12
  • Aug 11, 2017 3:16 AM UTC
Are you able to open the dwg file in AutoCAD environment? If yes, is it possible to provide the same here for review...
Pratap
chriswilson
  • Aug 11, 2017 3:41 AM UTC
Pratap
I'm not providing a DWG file to the process - the issue is that the reader fails and stops the process when ti has no file, despite the 'ignore failed readers' parameter being set to yes.
mygis
  • Aug 11, 2017 7:33 AM UTC
Hi @chrisw84 ,
From what I see FME cannot read the file. Cannot read it on FME Desktop? Just wondering is your Desktop and Server versions the same?
Could you please provide us with sample data and also the workspace? Perhaps At least the workspace.
Thanks.
danilo_fme
  • Aug 11, 2017 1:29 PM UTC
job-761.zip
Thanks for your logfile.
did you Run this workspace in the same FME desktop version in FME Server?
rylanatsafe
@chrisw84 - Is this the only Reader in your workspace? As per documentation for the 'Ignore Failed Readers' parameter, "If all readers in the workspace fail, FME aborts the translation, regardless of this setting."
Edit1: I misread your original posting. You have two Readers and when the Shapefile Reader successfully reads a file, you are correct that the RealDWG Reader (with that parameter set) should not fail out the workspace..
2017-08-11 08:51:26|   0.5|  0.0|INFORM|MULTI_READER(MULTI_READER): Adding REALDWG Reader with keyword REALDWG_2 2017-08-11 08:51:26|   0.5|  0.0|INFORM|MULTI_READER(MULTI_READER): Adding ESRISHAPE Reader with keyword ESRISHAPE_2
As some others have suggested, does this run without issue in FME Desktop?
Edit2: I have been unable to reproduce this issue with a sample workspace (attached). Can you provide your workspace and example data?
esrishape-acad2none.fmwt
mygis
  • Aug 12, 2017 12:38 AM UTC
Hi @chrisw84 ,
Thanks.
Hi @chrisw84,I can open your DWG file, however when I try to expose attributes, the same error occurs. Could it be that the dwg file you are reading is corrupted somehow or generated by a third party software which is not AutoCAD? Why not try on another DWG file?
chriswilson
  • Aug 14, 2017 3:12 AM UTC
Certainly did, I had the problem of developing in the wrong desktop version earlier this year and learned my lesson! Workspace here is developed in 2016 desktop and run on 2016 server. I'm about to post the workspace in answer to Rylan's request, so have a look there.
chriswilson
  • Aug 14, 2017 3:21 AM UTC
Here's the workspace:
cadastral-to-dwg-using-aoi.fmw
Bear in mind that a) I disabled the DWG reader to try the workspace out using the shapefile reader only.  This presented no reader issues, but only because I only let one attempt reading at all.  Also b) I have added a KML reader at an engineer's request, again, only letting one reader work at a time right now.  Finally c) the feature readers points to a very large dataset that is too large to share, but if you have a dataset with land boundaries, street addresses and road centrelines/street name this will do to test it out.
Sorry, and yes - it runs ok on Desktop beyond the failed DWG read.  I had tested it on desktop first.
Note in your case you are using the basic ACAD reader, whereas I am using the RealDWG reader.  I have not tried the other reader yet, as I use the RealDWG one as standard, but I should give it a try.
chriswilson
  • Aug 14, 2017 3:25 AM UTC
Hi guys. As I mentioned to Pratap in this case I am not attempting to read a DWG file - it is an optional reader depending on what the user wants to supply - DWG, shapefile or (as added since) KML to run through the process and return data for that area. Presently, when uploading a shapefile the DWG reader returns an error, despite 'ignore failed readers' being set to 'yes'. To me, 'ignore failed readers' should mean that when the DWG reader sees nothing is uploaded it shouldn't matter and the shapefile, or KML (which I haven't tested), should run through just fine.
mygis
  • Aug 14, 2017 7:16 AM UTC
Hi @chrisw84,
I would use a Generic Reader format rather than separate readers then you could separate the branches based on the format chosen by the user on FME Server/Desktop.
Cheers.
Lyes
chriswilson
  • Aug 14, 2017 10:03 PM UTC
Hi @chrisw84,
Cheers.
Lyes
Yes and thanks That one was mentioned by a colleague yesterday, I may give that a try or use a path reader as I have done otherwise. However to me the existing setup should not fail, so I would be keen to know what the issue is.
chriswilson
  • Aug 20, 2017 9:37 PM UTC
Hi @chrisw84,
Cheers.
Lyes
Accepting your entire comment here, as the generic reader and then a geometry filter for polygons was the answer. Cheers Lyes!
mygis
  • Aug 21, 2017 1:59 AM UTC
Hi @chrisw84,
Cheers.
Lyes
Hi @chrisw84,
glad that you managed to manage it ;)
