problems with dropping tables before update (postGIS)
  • Apr 10, 2014 9:37 AM UTC
  • 39 views
Hi all,
Just upgrading to the pro edition, and what a edition! :) Using the WFS reader to update a table in our local database (postGIS). So far so good. I want to run the workspace as a batch updating the table every night, which means I want to delete the content of the table before updating it. Somehow this dosen´t seem to work. I tried to google the answer, setting the parameter in the postGIS writer to UPDATE. Not working. Something I´ve missed?
I´m using FME 2014 SP1
Christian
Link to Workspace screenshot:
https://dl.dropboxusercontent.com/u/8365323/WFS%20%E2%86%92%20POSTGIS.png
fmelizard
Forum|alt.badge.img+22
  • Apr 10, 2014 11:03 AM UTC
Make sure the truncate table setting on the writer is set to yes and on INSERT instead of UPDATE. Check to make sure that the create table is set to no.
  • Apr 10, 2014 2:27 PM UTC
thanks for the answer. I´m uncertain about the create table parameter. Where is it located?
https://dl.dropboxusercontent.com/u/8365323/properties.png
fmelizard
  • Apr 10, 2014 5:41 PM UTC
yes, I see your point :) I am so used to it being there as an oracle user.....apperently the approach is slightly different in PostGIS.
The documentation (http://docs.safe.com/fme/html/FME_ReadersWriters/Default.htm#postgis/Writer_Directives.htm)indicate that the table name and other writer parameters control overwritting or appending. Always a good place to start from when in doubt.
