Problems encountered using Cesium 3DTiles Writer
  • January 23, 2025
  • 47 views
benwu
Participant
Excuse me, I am a master student. During one of my curriculum module, I used the Cesium 3D Tiles Writer in my project. And the result is not good:
As we can see, some of the lines of point cloud is missing.
And during the procedure of translation, I ahve warnings like this:
What’s more, is that the result put all points inside the same pnts file:
So when I try to visualize it on the website, it becomes stuck and process in a very low speed.
May I ask how should I manage the parameters inside the Cesium 3DTiles Writer? If anyone could help me, I will appreciate it.
aliatsafe
Forum|alt.badge.img+24
  • January 27, 2025
Hello, ​@benwu!
Thank you for posting your question to the community.
Sorry for the troubles you’ve been facing with the results the Cesium 3Dtiles Writer produces.
If you haven’t come across this community post, the latest response may help you out - putting it below for context too.
What you could try is first breaking up the point cloud into tiles using the Tiler, then use the Cesium 3DTiles Writer. The Tiler will assist in break things up and hopefully make it easier for the writer to process more detail.
Let us know if this works.
Thanks!
