Problem Reading FME created oracle spatial tables in ArcGIS
  • Jun 4, 2018 1:21 AM UTC
  • 7 replies
  • 104 views
I have setup the diminfo coordinates, i have created a spatial index and still I am unable to view the oracle table in arcgis. The table is in oracle with geometry and correct diminfo, why can't i see the table in arcgis.
  • Jun 4, 2018 1:36 AM UTC
My settings
austinh
Forum|alt.badge.img+4
  • Jun 4, 2018 1:42 AM UTC
@Jacq did you create a primary key constraint in your table. I believe Arc needs this to reads. Are you using ArcCatalog?
ALTER TABLE tableName ADD( CONSTRAINT id_pk PRIMARY KEY (ID));
austinh
  • Jun 4, 2018 1:51 AM UTC
Do you have a field in your data that can be used as a primary key (unique) and is an integer?
  • Jun 4, 2018 2:03 AM UTC
I just did that, using Toad for oracle, still unable to see the table in ArcCatalog
  • Jun 4, 2018 2:08 AM UTC
Yes, i used that field as the index field as well
  • Jun 4, 2018 2:10 AM UTC
snapshot of table
  • Jun 4, 2018 3:52 AM UTC
I still need some help, if anyone has any experience with this it would be much appreciated
