Problem :Insert new points through FME has no UT-Attribute Data
  • Nov 1, 2024 2:59 PM UTC
  • 0 replies
  • 55 views
jokerfme
Hello,
I have posted my question in esri community but I did not get answer yet .
i hope ,if someone could fix my issue  .
I am inserting points into an SDE version using FME, but after creating the point, I'm unable to edit the UT Attribute Data. My company uses UT-Editor (developed from ArcMap), and typically, when I create a new point in UT-Editor, a window automatically appears to fill fields in the UT Attribute Data.some fields are necessary to fill in like Adresse and … However, since I'm inserting the points through FME, when I use the UT Attribute Data symbol to select  the point to try  fill the fields in, the window does not open. How can I resolve this issue? Is there a specific method that would allow each new point to linkage to UT-Attribute Data by FME ? or How could open the UT Attribute Data window in UT-Editor for each new point ,come from FME ?
Thanks in advance .
FME 2021
