placing a point from coordinates in csv
  • Aug 15, 2014 1:42 PM UTC
  • 66 views
Hey
i am trying to do a simple workspace of placinig a point at Lat & Long coordinates within a CSV file
if i inspect the data i can see the coordinates
but when i link in the VertexCreator transformer and put it to Lat and Long, i get a error that it cant find the data
i have done this a few time before on different sets of data, but i cant seem to work this one out!!
cheers for any help you guys can give, i am sure i am just missing something simple!
cheers
gio
Forum|alt.badge.img+15
  • Aug 15, 2014 1:49 PM UTC
"bar 08" seems to miss coordinatevalues. At line7 in your csv.
Vertexcreator requires non-empty attributes.
  • Aug 15, 2014 4:49 PM UTC
also make sure that your system is using the same decimal separator as your CSV file.
If your CSV file contains "53.44" (point) but your system expects "53,44" (comma) it won't work. If that's the case, use a StringReplacer to set the correct decimal separator before your VertexCreator.
David
