Password protecting AutoCAD files?
zzupljanin
Forum|alt.badge.img+4
is it possible to create password protection on AutoCAD dwg files?
Thank you.
erik_jan
Forum|alt.badge.img+18
  • April 25, 2016
Could using a password protected template file work?
Just guessing, but worth a try.
zzupljanin
  • April 27, 2016
It's a good idea. But there are problems with it:
1. We don't have AutoCAD software (except Viewer). We don't need it since we provide solutions (not final products) to our clients. That's why I cannot even test if this workaround works.
2. That would imply that user cannot define its own password, or he/she would need to change password to desired one inside template file first, than run required fmw file. It's a bit awkward, but doable.
3. Acording to autodesk (http://help.autodesk.com/view/ACD/2016/ENU/?guid=G...) the password protection feature has been removed in AutoCAD 2016 release. Instead they suggest purchasing other encryption products.
Bummer.
Anyway, thank you for your reply
