Parse JSON from Bentley OpenGround
benicholls
I would like to be able to parse a response from the Bentley OpenGround REST API, and am getting somewhere but not far enough!
I can use a mixture of attribute exposer and JSONFragmenter to get some information out, but it never quite looks like the table i want. i will be doing multiple queries over the coming months into this api, and will have a different number of columns each time, so cant parse through each data record based on the number of columns i want in that particular query!
I can get to the point where i have a feature for every feature in the database, and then i have a _response_body which i need to parse further. i can keep parsing it through jsonfragmenter, and i end up with a jumbled mess where columns are names wrong and the colunn information i want is in the wrong part of the table. it is a simple structure, such as “DataFields” “heade” for column name and “value” for data itself. i will add some screenshots to aid in query. any help would be greatly appreciated!
Thanks
Ben
screenshot showing raw response for one attribute:
which i can parse with the json fragmentor, to get this,
and then i try to expose the attributes as follows, but the results are the wrong structure - columns like LocationDetails.LocationID with a value of “BS***” etc
nielsgerrits
Forum|alt.badge.img+55
Not sure if this is the best way, but how I do this:
  • Get a fragment for each feature.
  • Generate an ID for each feature. Can be done with a counter.
  • Fragment to the deepest array you need. json[*]["Datafields"][*] This creates a feature for each attribute.
  • Expose Header & Value.
  • Create an attribute with Header (@Value(Header)) as attribute name and Value as attribute value. This is a dynamic created attribute, so it will be unexposed.
  • Expose the attributes you created.
  • Remove unneeded attributes
  • Merge the attributes back into one feature using the Aggregator, group by the id generated at the start.
benicholls
  • April 29, 2024
this is so cool! thanks so much. ill give it a go now!
thanks again
ben
benicholls
  • April 29, 2024
H i there,
I gave this a good go, and adjusted the input data so it more accurately reflected the data i am getting back from the server.
i would love that the output has the GUID and then all of the attributes associated with that GUID
not have to manually expose each attribute - there are lots of attributes in the database, and i dont want to have to expose each one. not a proiblem if this is a necessary evil, fme is not magic!
your method worked but only for one feature, i assume that this is because the grouping can not be performed on the right attribute. i think the counter situation is weird and ultimately want to be able to use the GUID from the database itself if at all possible.
nielsgerrits
In this case, you want to follow the next steps:
  • Fragment to objects. The things with the attributes Id, Group, HasDocuments. Use json[*].
  • Extract the attributes (Id, Group, HasDocuments).
  • Fragment to key-values pairs.
  • Create attributes from key-value pairs.
  • Merge key-value attributes, group by Id, Group, HasDocuments.
I edited your workspace demonstrating this. See attachment.
It is possible to work around manually exposing the attributes for some cases, like dynamic writing with a schema feature. The SchemaScanner generates the Schema Feature from the data. But this is more advanced stuff.
