Oracle Writer - Error with dates
  • Sep 6, 2018 7:13 AM UTC
  • 9 replies
  • 183 views
roberto
Hello,
I’m getting an error that I don’t know how to handle.
Working with dates in Oracle writer, it seems that something wrong happens that convert in NULL the date provided. The date field (CREATEDTIME) is non nullable, so the workflow ends with the following error:
error was `ORA-01400: cannot insert NULL into ("CAD_OWNER"."MAPPIN"."CREATEDTIME")'
The field is of type “TIMESTAMP(0) WITH TIME ZONE”. So, using sqlExecutor, it accepts value like
'05-SEP-18 11:00:00.25 AM' and ends properly inserting the record.
I tried to do the same, placing an attribute with the same format in the Oracle writer without success. Also other dateFormatter seems not to obtain good results. I only need to insert a DateTimeNow().
Where I’m wrong?
Thanks!
Roberto
Best answer by steveatsafe
I tried to reproduce issues... But couldn't with what I know so far.  What version of FME are you using?
Here's what my attempt looked lie:
I created a table in Oracle:
CREATE TABLE SM_TEST_DATE2  (   ID1 NUMBER  , MYCOMMENT VARCHAR2(50)  , MYDATE TIMESTAMP WITH TIME ZONE );
Then I imported the feature type into FME 2018.1.  From there I created a simple workspace and added the DateTimeStamper and set the UTC Offset to yes. This created a record in the table.
However, if I didn't set the "UTC Offset" to "Yes" I got this error in 2018.1:
20180910151849.323846' is not an FME datetime. YYYYMMDD, HHMMSS[.X+][(+/-)zz] or YYYYMMDDHHMMSS[.X+][(+/-)zz] expected. Use a DateFormatter transformer to adjust the format of datetime strings.
In this image, you can see the error in the translation log.  Note that the transformer parameters in this image are correct and will create a valid timestamp for data type "TIMESTAMP with TIME ZONE" in FME 2018.1.
Also, I did notice that if the UTC Offset was No, a record was still created in the table but the Date attribute (MYDATE) was NULL.  This matches what you are reporting.
Hope this helps.
Forum|alt.badge.img+54
  • Sep 6, 2018 7:30 AM UTC
Try sending the date into the writer formatted as an FME datetime
  • Sep 6, 2018 7:34 AM UTC
I guess it's the same issue as this Q&A;: Problems to write field date in Postgis Database
  • Sep 6, 2018 7:36 AM UTC
And the same as @egomm's suggestion.
roberto
  • Sep 6, 2018 9:36 AM UTC
Thanks for the immediate answers.
Unfortunately this doesn't solve. I will continue with formatting.
In the meantime, waiting to solve, I will use sqlExecutor.
In your experience, which is the impact in terms of performances, writing/updating/deleting approx 3000 records every 3 minutes?
Is the writer faster (I think so) than multiple SqlExecutors?
Sorry for the question based on my reduced know-how on the product.
Thanks
Regards
Roberto
roberto
  • Sep 6, 2018 10:31 AM UTC
Thank
Regards
Roberto
erik_jan
Forum|alt.badge.img+26
  • Sep 6, 2018 2:15 PM UTC
You could also solve this on the Oracle side, by creating a trigger on the table:
CREATE OR REPLACE TRIGGER trigger_name
BEFORE INSERT ON table_name
FOR EACH ROW
BEGIN
IF ::NEW.CREATEDTIME IS NUll Then
::NEW.CREATEDTIME := Sysdate;
END IF;
END;
roberto
  • Sep 7, 2018 6:51 AM UTC
FOR EACH ROW
BEGIN
END IF;
END;
Erik,
I agree and I've done like this. Default value in the created time (sysdate) and trigger for modification. It solves my problem. Thanks.
steveatsafe
Forum|alt.badge.img+16
  • Sep 10, 2018 10:26 PM UTC
Hope this helps.
roberto
  • Sep 12, 2018 5:33 AM UTC
Hope this helps.
Steve,
thanks for your suggestion. I confirm that your hint solved the problem!
Best regards
Roberto
