Oracle Update sysdate problems
  • January 17, 2025
  • 8 replies
  • 120 views
g.bizournet
Hello,
Using a SQl executer
syntax:
update <table name>  set date_start= to_char(sysdate -1,'dd/mm/yyyy')
where  DATE_START is null
commit
No updates of the tables.
Does FME have a problem with using Oracle “to_char(sysdate -1,'dd/mm/yyyy')”?
Because the syntax works under ORACLE SQLPLUS
s.jager
Forum|alt.badge.img+16
  • January 17, 2025
What datatype is date_start?
It really should be a Date or DateTime, and you are trying to insert a string ( to_char ). You should never ever store dates and datetimes as strings. That it works in sqlplus could very well be because either SQLPlus is implicitly converting, or Oracle is, and the way FME tries to update probably prevents the implicit conversion (because of parameterized queries).
g.bizournet
  • January 17, 2025
Hi ​@s.jager Datetype in the databases is a DATE
s.jager
  • January 17, 2025
And yet you are trying to update it with a string.
Try simply sysdate-1, or even trunc(sysdate -1).
But do not use the to_char...
g.bizournet
  • January 17, 2025
still not working
g.bizournet
  • January 17, 2025
 sysdate-1 works in oracle, BUt not with FME
bwn
Forum|alt.badge.img+26
  • January 20, 2025
With SQLCreator/SQLExecutor, to diagnose you could check that the value is being parsed and calculated properly form the SQL string by
SELECT sysdate AS test_date_1 , sysdate-1 AS test_date_2 FROM <table_name>
This will at least suggest if the sysdate expressions are returning expected date values (in FME it should convert these into fme datetime format in the returned features from SQLCreator/SQLCreator)
If this returns the values fine, the problem may be be more in the attempted update operation itself rather than sysdate.
Forum|alt.badge.img+40
  • January 20, 2025
This code works for me
UPDATE MY_TABLE SET DATE_TODAY = (SYSDATE-1)
as does this
FME_SQL_DELIMITER ;
UPDATE MY_TABLE SET DATE_TODAY = (SYSDATE-1);
COMMIT;
g.bizournet
  • January 23, 2025
Hi
i know:  FME_SQL_DELIMITER ; UPDATE MY_TABLE SET DATE_TODAY = (SYSDATE-1); COMMIT;
this works
but not with sysdate -1,'dd/mm/yyyy'
But I fix this by:
  1. attributorCreator _dateYesterday  =   @DateTimeFormat(@DateTimeAdd(@DateTimeNow(),-P1D),%Y%m%d)
  2. DateTimeConverter  output %d/%m/%Y
  3. SQL executor  TO_DATE('@Value(_dateYesterday)','DD/MM/YYYY')
That works
