Oracle reader table name exposed as attribute?
  • Jul 13, 2018 3:50 PM UTC
  • 149 views
How can I expose the "table name" parameter in the dialog box of the Oracle reader as an attribute I can use in a writer (to force it lowercase)?
Best answer by andreaatsafe
Hi @hallkbrdz,
If you expose the format attribute "fme_feature_type" on the Oracle reader, you should get the Schema.Table name from the Oracle reader. Then you could use a StringReplacer to remove the "Schema." from the attribute values to get just the table name.
- Andrea
andreaatsafe
Forum|alt.badge.img+17
  • Jul 13, 2018 4:32 PM UTC
Hi @hallkbrdz,
- Andrea
