On the safe software site, I realize that there are only 64-bit FME products for Linux. I have a 32bit oracle database and obviously use a 32bit client. How will this linux FME enable the Oracle reader?
Oracle Reader in FME Linux
Best answer by david_r
You can connect to a 32-bit Oracle instance using the 64-bit Oracle client, no problem.
More information here: https://stackoverflow.com/questions/8813248/can-we-connect-a-32-bit-oracle-server-from-a-64-bit-client-and-vice-a-versa
