Offset error when referencing autocad drawing with template in FME
  • Oct 1, 2019 8:41 AM UTC
  • 38 views
Hi, I am generating dwg files in FME with the symbols from a DWG template. The file opens correct in Autocad but when using x ref they ends up with an offset.
Do I have set coordinate sytem, origo etc in the template or is it something I can do in FME?
Thanks Henrik
daveatsafe
Forum|alt.badge.img+24
  • Oct 1, 2019 5:03 PM UTC
Hi @hrinze,
If your source data and the Xref are in different coordinate systems, you can use the CsmapReprojector in FME to reproject the data when it is written to DWG.
