no valid xml to excel
  • December 12, 2016
  • 6 replies
  • 19 views
I have a xml document (someName.conf) which is not valid.
like:
<?xml version="1.0" encoding="ISO-8859-1"?>
<application name="....">
<component name="....">
<setting>
any comment
<name>Explorer.Service</name>
<value></value>
<enabled>false</enabled>
</setting>
<setting>
.... and so on
I have no xfmaps or other schemas.
I used different readers (generic and xml) and used some transformers like xmlFlattener but can't find to extract xml element/item with attribute.
output excel file should look like
column a -> comment
column b -> name
column c -> value
column d -> enabled
I`m using FME Desktop 2015.1
Any hint? thanks
Forum|alt.badge.img+50
If the XML is not valid there's a big chance FME won't be able to read it either. You can try this:
Create an XML reader, go into its parameters, set the Configuration Type to Feature Paths, find the Elements To Match setting and set that to setting, then enable flattening in the Flatten Options.
That way FME will try and make attributes out of everything it can find underneath that <setting> tag and you can map it to Excel.
Hope this helps.
  • December 12, 2016
Hope this helps.
Thanks for your hint. I will try this and let you know. :-)
  • December 12, 2016
I can transform my xml document ("elements to match" did the trick) to excel but comments are missing.
I will try different settings at reader level to export comments to excel too.
Thank you.
itay
Forum|alt.badge.img+17
  • December 12, 2016
If it's possible upgrade to 2016 that will provide you with a feature introduced in 2016 that scans the schema and returns all the xml elements in the input.
Hope this helps
  • December 13, 2016
Hope this helps
@itay do you mean that xml reader has a new feature in version 2016? Or is this a completely new reader? Do this read my comments by default or at least easier than in 2015?
itay
  • December 13, 2016
Hope this helps
@nhaz Its a new 2016 XML reader functionality, see the following article for more info
