Missing Data when writing to AGOL Feature
I am writing data to an AGOL feature but when the process runs, one field of the data does not get written. Everything else writes properly except for the one field. The field types are correct as other similar data is written out during the process.
Any ideas?
I have included a screen grab of the data preview in the reader, and the data table in AGOL.
Thanks,
--gary
lars_de_vries
Forum|alt.badge.img+10
You should check your logfile. It says 63 warnings and an error were encountered during processing. Usually I would expect that the field type doesn't match between what is offered and can be accepted.
But still, first check your logfile.
rahulsharma
Hi @bowlesg, Can you please share your logfile?
It appears it may be incorrect datatypes and the column is being skipped.
