Migrating Attachments GN to UN
  • April 1, 2024
  • 127 views
plancet10
Participant
I am currently trying to migrate my Geometric Network (GN) system data to the Utility Network (UN) and would like to include attachments in the FME workbench. Currently, I have a workbench that successfully migrates the points, lines and polygons (Assets, domains, and attributes) to target UN features but I am not sure how to handle attachments. Should attachments be handled in a separate bench?
The attachments would be mapped from the source tables to the new UN attachment tables. For example, hydrant attachment table would be migrated to Device attachment table
Can attachments be migrated using FME? What type of transformers and workflow needs to be utilized to move this type of data?
j.botterill
Forum|alt.badge.img+55
  • April 5, 2024
Hi there, in terms of can attachments be written to Portal or AGOL destinations? I believe a NEW packaged transformer is coming mid this year to assist here. You could try AttachmentWriter from the fme hub, a little old but edit it and adapt the transformers for your purposes. When reading existing AGOL feature with attachments, you need to expose the format attributes for “arcgisonline_attachment{}” list.
The type of workflow for writing, you will probably need to merge the FilePath to images using File and Directory path in a FeatureReader with the existing feature classes of the assets (based on objectID? or another ID). Ensure the image is moved into an attribute in the list ‘data’ using possibly AttributeFileWriter? When writing the asset, have the attachment format attributes ticked on and pass in the list? Also ensure attachments are enabled in the settings of the feature service.
I suspect you may encounter issues with existing Writer formats to Arcgis portal/online, hence the need for the packaged transformer coming this year.
Esri probably have python notebooks to upload attachments
aliatsafe
Forum|alt.badge.img+24
  • April 5, 2024
Hi, @plancet10.
This could be done in FME with either your original workspace or as a post-processing step. I would recommend doing it in a post-processing step.
There are two possible options. You could either use the custom transformer ArcGISEnterpriseAttachmentAdder or an HTTPCaller to call the REST API to upload the Attachment.
Either method will require you to have the features joined I believe, so that the Attachment will be added to the correct feature.
Hope this helps!
salvaleonrp
Forum|alt.badge.img+20
  • July 13, 2024
