Merged Cells in excel
  • November 9, 2015
  • 8 replies
  • 182 views
jdh
Forum|alt.badge.img+28
Is there any way to write merged cells in excel:
Best answer by mark2atsafe
Sadly, no, FME can only read, not write merged cells. However, if you were to use a template that already had the cells merged in it, I hope they would be preserved as such.
mark2atsafe
Forum|alt.badge.img+44
  • November 9, 2015
mark2atsafe
  • November 9, 2015
btw If you need proper merged cell writing support, please do contact the support team (www.safe.com/support) and ask them to file an enhancement request.
jdh
  • November 9, 2015
How would you go about setting up/writing to that template? I have no idea of the number of features that would result, but I know they would always be paired.
mark2atsafe
  • November 9, 2015
Well, I would do a bit of testing. Create a spreadsheet with Excel where two cells are merged (like in your image). Then try writing a couple of features from FME to that file. If you look in the parameters for the Excel Writer there is one for the Template File to use (i.e. write to this excel file and don't overwrite the structure). I'm not sure whether to expect the first feature to stay in the cell, or the second feature to overwrite it - but I'm confident that it would be consistent.
mark2atsafe
  • November 9, 2015
Just tried it. The first feature wins. So if Attr1 has values 1,2,3,4 and Attr2 has values 1,2,3,4, the cells are:
nb: I just set the template to use, but then had to set a feature type parameter to tell FME to start writing at cell A2.
Forum|alt.badge.img+38
  • January 22, 2019
I know there have been some significant changes to the excel writer since this post, are merged cells still not possible?
jkr_wrk
Forum|alt.badge.img+29
  • January 23, 2019
Tested in beta. I see no hints that it is possible now.
Vertical merged reads as missing attribute. Horizontal merged reads both cells as same value.
normal
normal
normal
Vertical mergedHorizontal mergednormal
normal
  • January 23, 2019
normal
normal
normal
normal
Thanks for checking
