Mapinfo writer not creating .ind file
  • Apr 1, 2019 10:39 PM UTC
  • 169 views
Good morning all, i am trying to work out how to get the mapinfo (mapinfo_extended, MITAB or MAPINFO) writer to output a .ind file.
when writing to mapinfo i get dat, id, map and tab but not ind file.
with the MITAB i have made sure that build optimal spatial index is YES but there appers to be no option for any of the mapinfro witters to produce a index file.
cheers
edit version, fme 2018.1.0.1 build 18528 win 32
Best answer by sipsysigh
Hi @qmangaming
In the Writer Feature Type Parameters dialog, under User Attributes, you need to select 'Indexed' against an attribute. You may need to make the dialog a little bigger to see the Index option.
This will generate an .ind file when writing out your .tab file.
sipsysigh
sipsysigh
Forum|alt.badge.img+12
  • Apr 2, 2019 7:40 AM UTC
Hi @qmangaming
sipsysigh
  • Apr 2, 2019 9:53 PM UTC
Hi @qmangaming
sipsysigh
Awesome, it was right in front of me all the time :)
cheers
