MapInfo .TAB file opens in FME Data Inspector but errors in FME Workbench?
  • Sep 26, 2017 1:57 PM UTC
  • 168 views
I have a MapInfo file which I am trying to convert to an ESRI Shapefile.
I can open the file using the MAPINFO reader in FME Data Inspector but when using the same reader in FME this returns the below error:
Failed to open native MapInfo file 'Biological_Heritage_Sites_Distribution_2012.tab' could not be opened as a MapInfo dataset.<br>
I have tried using both the 32-bit and 64-bit versions of FME but receive the same error in both.
The TAB file has all file elements within the same folder (.TAB, .ID, .DBF, .MAP)
I have also tried both the TAB and MITAB readers. Is there anything else you can advise to try?
Thanks in advance for your help with this.Thanks, Charlie
danilo_fme
Forum|alt.badge.img+58
  • Sep 26, 2017 2:36 PM UTC
Hi @cdoherty,
Could send the full log file? and your Source data?
Thanks,
Danilo
davideagle
Forum|alt.badge.img+21
  • Sep 26, 2017 2:49 PM UTC
I wonder if you mean .DBF? It's not usual to have a DBF file with a MapInfo TAB file, but it is with a Shape file. Could two similarly named files have cohabited unnaturally in the same folder perhaps? The normal storage file for a MapInfo files records is a .DAT file.
That said, as you have said it opens fine in the Data Inspector I think it's curious. I'd try:
- Open with MAPINFO reader
- Open with MITAB reader
- Open with MAPINFO Extended reader
- Try 32bit and 64bit FME
- Open with Data Inspector (where it worked) and chose File > Save Data As to see if you can export it from there to a Shape File. If so, that deserves a support@safe.com issue ticket to be submitted.
- Turn it off and on again... and start from the top again.
- Try it in an earlier build of FME available here.
All the best, Dave
Hi Charlie @cdoherty
if you can view your MapInfo table with Data Inspector but can not add a Reader in Workbench, we definitely need to take a look at your dataset. Could you please share it? If you prefer not to share the data here, we can open a support case and do this investigation through the case.
