Looping Empty Rows in Excel until new Column Value is found
  • May 12, 2020 4:44 PM UTC
  • 80 views
freddy17
Forum|alt.badge.img+8
Hello Everyone,
I have a question how to copy row data, but cant seem to find an efficient way to do it yet.
Below, attached is a Screenshot of the Original Excel file.
The idea is to take a cell value (in this case the 0.10 in the blue field at the top) and copy it for all empty column values until it reached the next filled value (0.20), which will then be copied downwards in the column.
So your result will look like this.
I assume with something like:
If CellValue Col x Value is Empty
Then Copy Col x - 1 Value to Col X
Continue to Col x + 1 and loop
Something along those lines.
Has someone dealt with this before?
Cheers
Fred
danilo_fme
Forum|alt.badge.img+58
  • May 12, 2020 4:53 PM UTC
Hi @freddy17
Could you share us a dataset?
Thanks in Advance,
Danilo
Forum|alt.badge.img+54
  • May 12, 2020 5:14 PM UTC
No, looping required, just adjacent attribute handling in an attributecreator with a conditional statement which basically says, if ColumnA has a value keep the value as ColumnA, if there is no value, use the value ColumnA from the feature above. Because FME processes the features in order, the value above is always completed ready for the next line
freddy17
  • May 13, 2020 8:35 AM UTC
Hi ebygomm,
Thank you for pointing this out, is a great time saver.
@danilo_fme, I have added my excel and the FME solution to my enquiry, works exactly how I would want it.
Regards
Fredcopyrowvalues.xlsxcopyrowvalues.fmw
