Logging certain information into text file
  • Jul 11, 2024 12:01 PM UTC
  • 302 views
jugoslaviaa
I have an ETL workbench and would like to create a text file where I can write some information while running the workbench. The information I would like to write includes:
  • The path to individual readers
  • The feature counts of each reader
  • The coordinate system of the each reader
  • How many objects have been written to the database
I don't want to use logging per se because it writes basically all information.What alternatives do I have? Can I only do it with python`?
Best answer by jkr_wrk
Use the FeatureWriter set to Text File
In Parameters select Overwrite Existing FIle: No
Make a attribute in  your workbench called text_line_data set it to the information that you want in the log file.
Let this feature(s) with the text_line_data attribute go to the FeatureWriter.
jkr_wrk
Forum|alt.badge.img+37
  • Jul 11, 2024 1:00 PM UTC
