Keep only columns in a PostGis data if they are not listed in the text file
  • Nov 15, 2019 10:20 AM UTC
  • 61 views
Hello
I want to export a table from PostGis databse by keeping only the columns that don't appear in a text file.
This is an example to be more clear :
Text_file : A B C Z
Table columns :
ID
7
T
Z
F
K
B
Export result:
ID
7
T
F
K
Thank you in advance for your answers.
Best Regards
Forum|alt.badge.img+63
You could read the text file and per feature in there have an SQLExecutor perform an ALTER table DROP column query.
However... this screams "massive SQL injection vulnerability" so I would recommend that you make really really sure the input text file is correct.
  • Dec 10, 2019 6:52 AM UTC
Hello and thank you very much for your answer. Sorry for my late answer.
Do you think there's any other way then this sql query ?
Thank you very much in advance for your answer.
Well... I'm no SQL wizard, but one thing you can try is
  1. Create a view (as SELECT * FROM table)
  2. Drop the columns you don't want from that view (with the ALTER view DROP column)
  3. SELECT * FROM view, run the data through your process
  4. Drop the entire view
Each step is a separate SQLExecutor. It'll leave the original table untouched.
nielsgerrits
Forum|alt.badge.img+67
This. But if you are not allowed to create a view (which is often the case in my experience) you also could generate the select query. I can think of two ways:
  1. Use a SQLExecutor to Retrieve all colunms from the table from information_schema.columns. (select * from information_schema.columns where table_schema = 'public' and table_name = 'spatial_ref_sys';)
  2. Get one row (select * from public.spatial_ref_sys limit 1;) and use an AttributeExploder to extract the columns. Remove all columns starting with fme_ using a Tester.
Then use a FeatureMerger to merge with the checklist (Supplier). Unmerged Requestors are the columns not in the checklist. Aggregator to concat all remaining columns, AttributeCreator to create select statement. (select srid,auth_name,auth_srid,srtext,proj4text from public.spatial_ref_sys;) Use a SQLExecutor to run the concatted selectstatement.
