Keep first feature after change
Forum|alt.badge.img+40
A 1 STARTED
A 2 IN PROGRESS
A 3 IN PROGRESS
A 4 PAUSED
A 5 IN PROGRESS
A 6 IN PROGRESS
A 7 COMPLETE
A 1 STARTED
B 2 IN PROGRESS
B 3 IN PROGRESS
B 4 IN PROGRESS
B 5 COMPLETE
I have a list of actions which are listed in the order they performed. Sometimes the actions do not result in a change in the attribute  I am interested in, so there are 'duplicate' entries. However I want to keep those duplicates where they appear either side of a status change.
So in the above examples I'd end up with
A 1 STARTED
A 2 IN PROGRESS
A 4 PAUSED
A 5 IN PROGRESS
A 7 COMPLETE
A 1 STARTED
B 2 IN PROGRESS
B 5 COMPLETE
I know how to do this in excel but I'm struggling to find a way to repeat it within FME
Best answer by takashi
I would use an AttributeCreator with the "Enable Adjacent Feature Attributes" option and a Conditional Value to create an attribute which indicates whether the record should be kept. And then, filter the records by testing the attribute value, with a Tester.
Assuming that the field name is "status", the AttributeCreator parameters setting looks like this, for example.
Takashi
  • July 9, 2015
Takashi
  • July 9, 2015
Perfect, I'd never used those options within the AttributeCreator before
