JSON Splitter
  • November 29, 2019
  • 249 views
soothsayers
Forum|alt.badge.img+7
Hello,
I am new to JSON formatted strings and have spent a few hours trying to split out some content with JSON Extractors and Fragmenters with no luck. I have an array of 10 "items" which I need splitting into separate features.
What I need to pull from each item is the publishedParameters list (as a split list) and WorkspacePath.
So they resulting objects should be formatted as such:
Item# ¦ WorkspacePath ¦ publishedParameters
0 ¦ "APIrepository_prod....." ¦ "name": "user_email", raw: "Glenn.sayers@halliburton.com"
0 ¦ "APIrepository_prod....." ¦ "name": "cell_size", raw: ""
0 etc.
1 ¦ "APIrepository_prod....." ¦ "name": "_layers_other", raw: ""
1 ¦ "APIrepository_prod....." ¦ "name": "_layers_gde", raw: "present_nonclipped.gde_drainage,..."
1 etc.
I have attached the full JSON in a text file.
Many thanks,
Glenn
Best answer by soothsayers
Thanks for your help guys, I have now got this working. It's not exactly how your examples worked but they were very useful. I used something similar to your multiple JSONFragmenter example @takashi, filtered out just the WorkspacePaths I needed, then crucially set a counter on them.
Splitting out the request.publishedParameters shown in the list in your image @daveatsafe, I could then aggregate them back up based on the Counter result. Finally I then could expose the request.publishedParameters to get the attributes needed to FeatureMerge other incoming data based on these attributes! Wonderful!
daveatsafe
Forum|alt.badge.img+19
  • November 29, 2019
Hi @soothsayers,
Please try the following settings in the JSONFragmenter:
This will produce the following results:
You can use the JSONTemplater to create the new JSON in the format you want, or a ListConcatenator to merge the list elements into a formatted string.
  • November 30, 2019
Hi @soothsayers, if I understood your requirement correctly, this workflow might help you.
soothsayers
  • December 4, 2019
