Json extractor nested arrays
jdh
Forum|alt.badge.img+28
I have a json object that contains nested arrays, a simplified example is:
   "Attr1" : [{
      "Attr2" : [{
         "Attr3" : "A"
      "Attr2" : [{
	 "Attr3" : "B"
	 "Attr3" : "C"
      "Attr2" : [{
         "Attr3" : "D"
	 "Attr3" : "E"
	 "Attr3" : "F"
I would like to extract just attr3, either as a (complex) list, or a valid json ex. [{"Attr3":"A"},{"Attr3":"B"},{"Attr3":"C"},{"Attr3":"D"},{"Attr3":"E"},{"Attr3":"F"}]
If I use the JSONExtractor with json["Attr1"][*]["Attr2"][*]
I get {"Attr3":"A"}{"Attr3":"B"}{"Attr3":"C"}{"Attr3":"D"}{"Attr3":"E"}{"Attr3":"F"}'
without commas between elments.
The JSONFlattener with recursion does work, but the actual json has a couple of hundred additional elements, and I would like to avoid creating them unnecessarily if possible.
Best answer by takashi
Hi @jdh, I would use the StringReplacer to replace }{ with },{ after extracting the elements by the JSONExtractor.
[Addition] An example: json-to-list.fmw or json-to-list-2.fmw
deanatsafe
  • March 24, 2016
Hi @jdh
I used JSONFragmenter with json["Attr1"][*]["Attr2"][*]["Attr3"]
This yields 6 records with _result = 'A', _result = 'B', etc
Then to make a list I used a ListBuilder which generated `_list{}._result' = {A,B,C,D,E,F}
See attached: json2list.fmw
Dean
  • March 24, 2016
jdh
  • March 24, 2016
deanatsafe wrote:
Hi @jdh
Dean
I thought of that, but I really want to avoid using blocking transformers for performance reasons.
jdh
  • March 24, 2016
I've never tried the @ReplaceString in the text editor. I'll have to remember that in the future.
deanatsafe
  • March 24, 2016
No need for it to be blocking if you have a feature id to group by in the ListBuilder. If not you can make one with a Counter
