JP2 reader
  • Aug 8, 2017 3:14 PM UTC
  • 133 views
Has something changed within the JP2 reader between FME2014 SP4, and FME2017? I'm using a simple workbench to convert from JP2 to Geotiff, which worked fine in 2014. I'm getting a message in 2017 that I do not get in 2014, "JPEG2000 reader: Mercator projection should not define both StdParallel1 and ScaleatNatOrigin. Using StdParallel1 and ignoring ScaleatNatOrigin." The resulting geotiff does not seem to retain the coordinate system.
Once the geotiff is written, this is the error I'm getting in Photoshop/Geographic Imager:
"The coordinate system in this reference file is not valid. Failed parsing wkt string <LOCAL_CS["NonEarth_Meter",UNIT["metre,1,AUTHORITY["epsg","9001"]]]> with error <GeoCalc Exception Cannot Import Coordinate System from file/stream: Failed parsing WKT/PRJ String.>."
I do not get this error in PS/Geographic Imager when converting the file using FME2014.
mark2atsafe
Forum|alt.badge.img+59
What coordinate systems do you have set for the source or destination? For what it's worth I see no other reports of this error message appearing in FME, so it's not a known issue, and it's more than likely a setup issue I think.
