Issues writing ProxyType to IfcProxy
  • May 13, 2021 2:06 AM UTC
  • 82 views
ekkischeffler
Forum|alt.badge.img+7
I'm writing and IFC file and I am writing objects into IfcProxy as there's no other fitting IFC Type at the moment. To better define the type, I am using the default ProxyType attribute.
When I write ProxyType as attribute in FME, the IFC file breaks. I can see the information added in the file but apparently the syntax is wrong. The FME output looks like this:
#674=IFCPROXY('b4I2bLVTRhe0Uu99isXLTw',#24,'Stone | CCC','Wastewater asset ID: cac582d1-373d-4ff8-bada-9727e139562a',$,#673,#672,.Sewer.,$);
In this case ".Sewer." is the ProxyType value. Then I change the IFC file to contain this instead:
#674=IFCPROXY('b4I2bLVTRhe0Uu99isXLTw',#24,'Stone | CCC','Wastewater asset ID: cac582d1-373d-4ff8-bada-9727e139562a',$,#673,#672,'Sewer',$);
After this change (replacing . with ') the IFC file works and the ProxyType information can be read.
Is this a bug or a mistake on my side?
Best answer by daveatsafe
Hi @ekkischeffler​ ,
I don't think you can use the value of 'Sewer' for ProxyType. According to the IFC specifications, the ProxyType of an IfcProxy feature is an enumeration, and should be one of the following values:
  • PRODUCT
  • PROCESS
  • CONTROL
  • RESOURCE
  • ACTOR
  • GROUP
  • PROJECT
  • NOTDEFINED
Please try using one of the values above, and see if the results are valid.
daveatsafe
Forum|alt.badge.img+24
  • May 14, 2021 3:59 PM UTC
  • PRODUCT
  • PROCESS
  • CONTROL
  • RESOURCE
  • ACTOR
  • GROUP
  • PROJECT
  • NOTDEFINED
ekkischeffler
  • May 19, 2021 4:50 AM UTC
  • PRODUCT
  • PROCESS
  • CONTROL
  • RESOURCE
  • ACTOR
  • GROUP
  • PROJECT
  • NOTDEFINED
Thanks very much @daveatsafe​ , that solved it. I should have thought of that!
