Is there a way to transform IndoorGML (xml but not normal xml or GML) to Esri Shapefile?
Best answer by deanatsafe
The XML reader will work if you are on FME 2015 or prior, but the easiest thing to do is download FME2016 and use the new IndoorGML reader.
erik_jan
Forum|alt.badge.img+19
  • January 13, 2016
You will have to use the regular XML Reader. Point to the top tag in the XML (if you are using FME 2016 this will be displayed as a tree window, before that you have to get it using a XML editor).
Flatten all attributes but exclude the geometry object (that needs to be one attribute and not be flattened).
The use the GeometryReplacer to create a geometry from the GML geometry attribute.
It will be a lot of trying and re-trying but it can be done.
deanatsafe
  • January 13, 2016
erik_jan
  • January 13, 2016
Did not know this. So use FME 2016 and disregard my answer!
