Is there a way to distinguish feature types whether they are real tables or views?
I need to reproject feature coordinates (with ReframeReprojector) coming from an Oracle Spatial Object reader and therefore want to exclude feature types that are views from being reprojected.
Manuel
erik_jan
Forum|alt.badge.img+20
  • December 21, 2016
You can use the SQLExecutor transformer to get information from the TAB table in the Oracle database (Select tabtype from TAB where TNAME = '@Value(fme_feature_type)'). This will show if the fetaure type is a VIEW or TABLE.
itay
Forum|alt.badge.img+17
  • December 22, 2016
Optionally you can just filter out the views if the information can be found in feature type (e.i using V or VW for view in the feature type name) eventually try avoiding reading the views if the naming is consistent by using the Feature Type To Read parameter.
Hope this helps.
