Is there a simple way to add a 'total' row to a Excel Writer?
  • Apr 3, 2020 8:46 AM UTC
  • 6 replies
  • 266 views
benvk
Forum|alt.badge.img+8
I am outputting many rows to an excel table, some of my columns are numeric, I am hoping to add a total row at the bottom of my table, to sum these columns. I have found the Statistics Calculator, but I have no idea how to apply it (if at all possible).
Any thoughts?
Best answer by markatsafe
@benvk For FME 2020 we revamped the StatisticsCalculator to make it faster and easier to use. So that is now a good alternative to the Aggregator.
  • Apr 3, 2020 9:42 AM UTC
Hi @benvk, I would use the Aggregator with the Attributes to Sum option to do that. See the screenshot below. Assuming attr1, attr2, attr3 has numeric values.
  • Apr 3, 2020 4:57 PM UTC
gazza
  • Apr 3, 2020 8:19 PM UTC
Another option is to let Excel do the work by writing a SUM formula after your data. I've written a blog post about how to do this here.
To make this dynamic I like to use this formula:
=SUM(INDIRECT(ADDRESS(1,COLUMN())&":"&ADDRESS(ROW()-1,COLUMN())))
or if there is a header sell then
=SUM(INDIRECT(ADDRESS(2,COLUMN())&":"&ADDRESS(ROW()-1,COLUMN())))
benvk
  • Apr 6, 2020 12:51 AM UTC
I can see the results in the statistics calculator, they look correct. I still am perplexed how to get FME to insert a row in the sheet to show these totals?
fme_can_do_it
Forum|alt.badge.img+13
Hi ​@benvk were you able to insert the row into your Excel report? I am trying to do the same thing, specifically inserting a row that calculates the difference between the values in a column. Thank you!
saraatsafe
  • Feb 28, 2025 8:54 PM UTC
Hi ​@fme_can_do_it, I’d suggest trying out the AttributePivoter to create a totals column. The example in the transformer’s documentation serves as a good starting point for this. I hope this helps!
